Hello friends,
I have a QU16 since January 2020. I have been learning on my own through tutorials.
Do you know if an input channel can be duplicated?
For example, what comes in through channel 1 (kick drum) that also enters a copy in another channel.
I will be attentive to your comments.
Regards.
this is only possible with stageboxes
since these allow patching the sockets to different input channels
Could he not send it out a different mix out? thus having two separate outputs. Obviously any changes to one would happen to the other, unless there is a way to process each mix output differently? Can’t remember off the top of my head as my studio is in bits at the moment whilst I do a full rewire.
not everybody is using the mixer in a studio situation
maybe he only want to process the same signal twice for live mixing…
and he was asking for inputs…
a Y cable adapter could do the trick
exactly Steffen, I’m practicing at home to work with live mixes.
Could someone explain the I / O Patch - Monitor function? see image…
The monitor IO patch function is for the ME series monitor mix stations.
If your not using the ME monitor mix station that IO patch menu has no effect
on anything.
Do not confuse the the ME series monitor mix stations/pods with the QU You
monitor mix app, their two completely different things.
Thank you very much Mike, now its use is clear to me.
Regards.
