Duplicate channels on ilive
Hi everyone,
Can someone please tell me how to duplicate channels on the ilive so I can have a separate parametric for the monitor mix.
If you have the space on the surface, you just have to address the 2 separate strips to the same mix rack input.
The split occurs after the pre-amp module so any pre-amp adjustment affects both channels.
Due to that, I would advise that you set only 1 channel with actual pre-amp control, or leave the pre-amp set and set both channels with digital trim only.(this is a setting on the pre-amp parameter screen per channel or system wide on all channels)
I suppose I should have asked what are you working with, surface, rack, firmware version, single/dual rack setup, etc,
Thanks sparky,
I am using an ilive t12 and idr48 mix rack. I have more then enough channels, I understand the duplication shares the same pre amp and just cant remember which sub menu to go into and how to actually do it once I am there.
Kieran
“Surface” button near the screen, tab “Strip setup”, the press select on the desired channel in appropriate layer/bank and chose the channel/mix/dca/whatever. That’s it.
If you want to assign just one channel, make sure the Block selection parameter is not active on the screen.
ddff
Thanks mate, I appreciate it I’ll be at the desk on Thursday so I’ll give it a go.
