It would be great to be able to sent the L/R feed to one or more of outputs 1-6. This could be tapped before the output processing for main L/R.
While the “Alt-outs” of the CQ-20 allow you to duplicate other outputs, you don’t have any processing control on those outputs.
Use case: using output 1-6 for additional main speakers, e.g., fills or subs, and then while still being able to use EQ on each output to give each speaker what it needs or set up crossovers.
I found this comment that might be useful from Keith:
https://community.allen-heath.com/forums/topic/send-main-out-to-one-of-the-outputs-1-6#post-118664
It is not possible to send the main mix to the other outputs as the main LR mix runs in parallel to the other outputs in the core (rather than before/after).
What you can do however, is set the output to be post fader in the config screen.
If you then set all channel sends to 0dB, that output mix will follow the levels going to LR.
An added benefit of this is that you have separate output processing and overall level control for just that output.
