duplicate outs mixer & D Snake
I have tried to find the answer to this but cannot find it - even in the manual.
If I need 2 left and 2 right outputs, can I do this by using both mixer L and R AND D snake 11 & 12 outs at the same time? Thanks
Hi Debz,
You can indeed!
The local IO on the back of the console is fixed, so signal is always fed to these outputs. When you attach a dSnake expander to your mixer, there is a default patch which can be changed to whatever you want. There are also some more options available to patch when using dSnake, like PAFL for example, which can be assigned to an XLR output.
Alex
Thank you Alex
