Duplicating Inputs
It’s probably something really simple, but I’m stumped.
I want to send a copy of an input to another channel so I can process it differently and merge the result.
From the target channel, I hit ‘Source’ to assign the desired input channel, and in the Reference Manual, it says hit ‘Select’ to confirm. Except, in the iPad App there is no ‘Select’ button.
In the Qu-SB Quick Start guide, section 7.2, on the processing screen, I select my desired input channel, but again no ‘Select’, ‘Ok’, or ‘Confirm’ button. So any selection I make doesn’t ‘stick’.
Help please.
Not enough info.
Are you using local inputs, digital stage box or what?
Input split only possible when sourced from dSnake.
I have a Qu-SB, and using local inputs
Andreas,
That’s a shame, but thanks.
It’s one of the defining features of the qu that make it very ‘analogue friendly’
Matters less on the SB of course, but that’s why.
