DX164-W - DC Powering
Hello,
I’m looking for more info on powering the DX164-W with DC. What is the DC barrel plug size? Does A&H or anyone else have recommended model PSUs? Is there a more precise voltage range given there will be some voltage drop if I run 12AWG about 100ft? Thanks!
The device requires 12v and 3A. You’ll need to calculate voltage drop yourself but I would expect something in the region of 10% loss over that distance.
The jack socket has a pin diameter of 2.5mm and an outer diameter of 6.3mm.
