The Ready LED on the DX168 does not light up when it is connected to the SQ-6. Only the Power LED is illuminated, and neither the LNK nor Err LED comes on.
I have tried different cables and a different mixer, but nothing helped. The DX-A port looks fine.
The SQ-6 works correctly with another rented stagebox.
What else should I check?
I don’t know what the LED lights look like when a stage box is connected to a console that is running a different firmware version. But if that happens, I know the box will not appear in the console as a routable source/destination. The good news is that the console will automatically “update” the stage box to whatever firmware version the console is running. This process can take some time however and also requires that the stage box be connected directly to the console (ie not daisy chained off another stage box where the other stage box is the device connected to the console).
So if you haven’t plugged the “non-functional” stage box directly into the console with everything powered up, and left it alone for perhaps 10 minutes (so it can complete the update process) that would be my first suggestion.
If you have done this, and there is still no signs of connection on the stage box, then I would suspect a hardware failure of some sort on the stage box that is preventing it from working correctly.
Have you tried switching the box to “redundant” mode (it’s currently in cascade mode based on your image) and then plugging it in using the “B” (the second/redundant) ethernet port? I’m grasping at straws here, but it is easy enough to try! That might work if there is a problem with the A port.
Yes, we tried that. The Link LED for that port is not blinking either.
Given all of that, unfortunately I think there is a hardware failure. If you haven’t done so already, I would reach out to the “official” A&H support team via the main A&H website. (This is just a user forum). They can help troubleshoot it or point you in the right direction if you need to send it in for repair.
There might be a way to test to see if the network light even turns on. Try the DX168 on a laptop’s Ethernet port or a switch. If the box’s Link LED still stays dark, it’s probably the hardware.
Any working Ethernet device should make the link LED light up if the box’s physical Ethernet circuitry is alive. The DX168 shouldn’t need the SQ-6 to negotiate a link, only to talk audio. So you can try the Ethernet hardware on its own:
- Power the DX168 on.
- Plug a known-good Ethernet cable from DX-A into your laptop’s Ethernet port (use a USB-C/USB Ethernet adapter if the laptop has no port), or into a regular network switch or router.
- Watch the Link/Err LED on the DX168 and the port lights on the laptop or switch.
If you see:
- DX168 LED lights or blinks, or the laptop/switch shows a connection: the Ethernet circuitry works, so the problem is more likely something in the DX-link handshake. That would be odd given your description, but worth knowing.
- Nothing lights on either end: the port or the box’s Ethernet circuitry is dead. That confirms hardware failure.
Is the product new or used? Has the light worked before? It could be a fault in the stagebox if another stagebox worked just fine.
I contacted technical support through the website, but because I was born in the “wrong” country, they refuse to help me ![]()
So now I’m on my own.
I don’t know whether anyone has investigated this issue in such depth before. I couldn’t find any relevant information online.
I disassembled the unit and checked it carefully. All the required voltages are reaching the board. I also tested the ports with a multimeter, and everything appears to be fine. I also connected them to a WiFi-router, but there was no response.
The next components in the signal path are two HX1198FNL transformers, which also appear to be working properly. There is no continuity between their windings and each other.
After that, there are two 88E3015-NNP1 Ethernet transceivers. They receive 3.3 V, and the reference voltage is also present. When the unit is powered on, Reset is released and goes high.
I couldn’t detect any clock signal from the oscillator at the Xtal_in pin, although I may have been probing it incorrectly. There are two oscillators on the board, and both appear to be working and producing 25 MHz.
The next component is an XC6SLX16 processor, and its power supply is present. On the back of the board, there are what appear to be test points. If I identified them correctly, the Done pin goes high. However, the Init pin appears to be shorted to ground. It remains that way after power is applied, although I may have identified the wrong test point.
There is an LED next to the processor. It seems to me that it should light up if the initialization is successful, but it remains off. There are also several LEDs near the voltage regulators, and those are illuminated.
There is also flash memory, apparently an MT25QL128. However, testing it without the firmware wouldn’t really be meaningful.I checked the board with a thermal camera, but nothing is overheating; everything remains at room temperature.The more I look into it, the more I think that this is not a hardware failure but a firmware failure.
There are connectors on the board for reprogramming, but I don’t have the firmware.
If anyone has a working board available, I would be willing to buy it.
Contact me the1plushka at gmail.com
Do you know anyone else nearby that has an A&H digital console that you could take the box to and try connecting to their console? It’s a long shot, but perhaps connecting it to a different console will initiate the firmware download/update process which is suppose to occur automatically.
Yeah, tried to connect it with another mixer. No luck
Is there any more progress/information on this, because I just had the same issue: power light on, ready light not on, network not lighting up on both A & B, no firmware issue
There is no solution yet
