Dyn8 reverts after loading show
Hi all,
When I load a show, my Dyn8 inserts reverts to default viewing, with neither the MB comp or DynEQ selected. I don’t know if it’s purely visual or if it actually isn’t active after loading. Set parameters are correct when I hit my DynEQ to view settings and behaviour.
Is this an issue with the 1.6 firmware?
Cheers
Gustav
Hi Gustav,
That’s expected behaviour, it’s the default view for the Dyn8. All Dyn8 processing is active at the same time, both the multiband and 4-band DynEQ. Changing tabs doesn’t switch elements on/off, it’s just a matter of what screen you are looking at.
Great, thanks!
