Dynamic EQ Plugin on SQ5
Is the addition for Deep Processing of plugins with dynamic equalizer planned?
It exists on GLD and on dLive, could it also have on SQ Series?
Thank you.
Hi Poli84
it has not yet been confirmed officially but rumour has it dynamic eq, multiband compression and de-esser will be included as a deep plugin upgrade option on the next firmware release expected for release shortly.
FYI there are several other posts discussing this if you browse the forum-including a photo of a presentation slide from NAMM!
cheers
Hello, how are you!
What would be more interesting for SQ would be a GEQ plugin that could be inserted directly into the input channels and not the outputs that already have their factory GEQs. I do not see any utility to buy a GEQ plugin if it can only be inserted in the outputs that in the case already have
