Easier routing reset
So one thing I’ve noticed is that it’s really irritating to reset routings on channels. I have to reset the channel, then select it, then reset the routing. It doesn’t sound like a big deal, but it’s a really awkward movement to make it happen, and more often than not, I end up messing it up. What if a double tap on the select key of the channel reset routing? i.e. hold down reset, press select once for normal reset, press again for routing reset. Then you could go down a channel strip and reset all parameters of a channel in one go.
