I’ve just started using Groups and was wondering if there is a quick way to see what channels are assigned to the groups? DCA’s allow you to easily see what channels are assigned to the DCA’s. I know you can look at the routing page and see a small pink dot indicating a channel is part of a group. My current workflow for assigning to groups is to use the Assign button on the mixer:
- Select L/R mix, hold assign and un-assign mixes from L/R.
- Select a group, hold assign and assign the same channels to the group.
Is this the quickest most logical way of doing this? Thanks…
