This might be a silly, but I have some long live Qu-Drive multi-song recordings. I have them imported into a DAW for mixing, but I’d also like to split some of the songs out for mixing on the QU.
It occurred to me might edited sections like this be exported back to a formatted Qu-Drive -as long as the file naming was correctly followed?
Hi Mixsit,
Here are the guidelines for formatting files so that they can be played using Qu-Drive: https://www.allen-heath.com/media/Qu-Mixer-Reference-Guide-AP9372_10.pdf#page=54&zoom=auto,-274,826
In a nut shell, the files need to be named and formatted in the same way as when you record them. They also need to be the exact same length and size.
If you have any trouble with this, please start a ticket at support.allen-heath.com for further assistance.
Alex
Great. Thanks. I was thinking the mixer might add or do something unique to its recorded files.
Hi Mixsit,
Actually, it usually data which a DAW may add, such as markers, which can cause an issue here. So make sure there is extra data added to the files when you export. I usually use the Force WAV setting in Reaper for this with BWF off.
Alex
