Editor 1.9 on MAcbook
Hey Guys.
I got problems running the editor 1.9 on my macbook. The application does not start. I already thought about Java and updated it, without success.
OSX 1.07.5 and Java SE6 and 7 are installed. If anybody has the same problems and a solution, please help me.
Best regards
JOhannes
Hi Johannes,
Could you get a terminal window open and type:
java -version
I’m running 10.7.5 on Java 1.6.0_37 and its OK for me.
Could you contact tech support, and include any output generated by performing the following commands:
cd /Applications/iLive Editor 1.90.app/Contents/Resources/Java
java -jar -Xmx580M ./iLive_Editor.jar
When entering the paths, try typing a little, then hit the tab key - the autocomplete speeds things up !
Cheers
Andy
A&H
thank you. i did what you said. i also want to tell the terminal issues to the forum:
When i start it with the terminal by typing this:
"cd /Applications/iLive Editor 1.90.app/Contents/Resources/Java
java -jar -Xmx580M ./iLive_Editor.jar"
the software starts, but it doesn’t load to 100 percent.
terminal says:
Johanness-MacBook-Pro-2:~ johannesdressel$ cd /Applications/iLive Editor 1.90.app/Contents/Resources/Java
Johanness-MacBook-Pro-2:Java johannesdressel$ java -jar -Xmx580M ./iLive_Editor.jar
Nov 13 11:12:14 Johanness-MacBook-Pro-2.local java[2439] : CGContextGetCTM: invalid context 0x0
Nov 13 11:12:14 Johanness-MacBook-Pro-2.local java[2439] : CGContextSetBaseCTM: invalid context 0x0
Exception in thread “AWT-EventQueue-0” java.lang.UnsatisfiedLinkError: /Applications/iLive Editor 1.90.app/Contents/Resources/Java/idr-livesim.dylib: dlopen(/Applications/iLive Editor 1.90.app/Contents/Resources/Java/idr-livesim.dylib, 1): no suitable image found. Did find:
/Applications/iLive Editor 1.90.app/Contents/Resources/Java/idr-livesim.dylib: mach-o, but wrong architecture
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary1(ClassLoader.java:1939)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1864)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1825)
at java.lang.Runtime.load0(Runtime.java:792)
at java.lang.System.load(System.java:1059)
at com.allenheath.ilive.cSim.(cSim.java:102)
at com.allenheath.ilivesystemmanager.ciLiveSystemManager.StartSim(ciLiveSystemManager.java:896)
at com.allenheath.ilivesystemmanager.ciLiveSystemManager.ConnectToUnits(ciLiveSystemManager.java:843)
at com.allenheath.ilivesystemmanager.cNetworkConnectionsWin.StartConnection(cNetworkConnectionsWin.java:338)
at com.allenheath.ilivesystemmanager.cNetworkConnectionsWin.NextOKAction(cNetworkConnectionsWin.java:419)
at com.allenheath.ilivesystemmanager.cNetworkConnectionsWin$cNextOKButtonMouseAdapter.mouseReleased(cNetworkConnectionsWin.java:456)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:290)
at java.awt.Component.processMouseEvent(Component.java:6505)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3321)
at java.awt.Component.processEvent(Component.java:6270)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4861)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4687)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:703)
at java.awt.EventQueue.access$000(EventQueue.java:102)
at java.awt.EventQueue$3.run(EventQueue.java:662)
at java.awt.EventQueue$3.run(EventQueue.java:660)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:676)
at java.awt.EventQueue$4.run(EventQueue.java:674)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:673)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:244)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:163)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:147)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:139)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:97)
the installed java version is: Java™ SE Runtime Environment (build 1.7.0_04-b21)
Johannes
Hi Johannes,
Thanks for the quick reply, could you open a support ticket with this information at:
https://allen-heath.helpserve.com/Tickets/Submit
Could you also include the information from:
About This Mac → System Report → Hardware → Model Identifier, Processor Name.
Cheers
Andy
A&H
