I was using editor off line to check out some settings on different shows then remembered some of the shows were done on T80 and idr48 and some on R72 and idr32. Launching the editor in T80 idr48 configuration it quite happily recalled shows from the R72 idr32 . This in itself was not a problem but there is no indication on screen about the hardware configuration ie which surface and rack was used once editor is open neither can you change this unless you close the program and re-start. Unless I’m missing something?
