There is already a custom window in the editor 1.5 where you can have different tab’s to quick switch to the layout you want. You can place whatever combination you want.
about the seperate PFL. You need the hardware available in the rack to have one pfl on the surface and a different one on the rack. I supose that isn’t the case. That’s why you would need a second processboard ( IDR32/48 or IDR0, IDR10) .
Used the laptop with touchscreen for monitor mixing ( split 32 channels )last weekend.One problem i found: when you select PAFL by accident then the headphone output on the surface changes to the selected ( monitor ) channel. That’s a little bit sceary for the FOH guy.Is it possible to disable the PAFL button in the editor in the next edition? Also it would be great to be able to have the headphone output on the rack to be a different source as the one on the surface so you can use it to monitor on stage. in order to be able to do that now you have to buy a IDR0 and 2 ACE cards ( 4000.00 euro without taxes ) that’s a litte heavy for een monitor headphone/wedge capabality. I now, you get also extra 64 channel everything and 8 EFX but i don’t need that now.
Will this ever be possible? I don’t wanne buy an IDR0 in the end and find out that in the next release this feature is supported.
Is it possible to do gain tracking in the future? Auto monitor trim when surface preamp( or surface trim in lock mode) changes? would be handy.
Large MIX an SEL BUTTONS please
Lieven
T112/IDR48
Disclaimer: I disclaim everything. The contents of this message might be totally inaccurate, inappropriate, misguided, or otherwise perverse - except for my name (hopefully I got that right).
