Since it’s currently not possible to select a mix using MIDI, does anyone know of a way to select a mix using the keyboard? i.e. Press F1 for Aux 1, press F2 for Aux 2, etc. I’m running Editor 1.80 on Ubuntu Netbook Edition 10.10
quote:
Originally posted by Clayton C. RackleySince it’s currently not possible to select a mix using MIDI, does anyone know of a way to select a mix using the keyboard? i.e. Press F1 for Aux 1, press F2 for Aux 2, etc. I’m running Editor 1.80 on Ubuntu Netbook Edition 10.10
you can do this with the softkeys…
RayS
R-72/iDR32/iPS10
The softkeys control the surface though, not iLive Editor.
Only options I know of to select a mix is to select it directly in Editor, use a Pl remote or a connected surface. It would be be good to be able to assign PC keyboard commands to mix’s though!
Drop that idea into the suggestions thread!
Cheers
Richard Howey
Audio Dynamite Ltd
IDR48/IDR16/T112/R72
