No desk, only editor connected to IDR48 via LAN cable - no wireless.
I’m having problems with the editor freezing. Can’t control anything, but i can close down the editor (and save ex. custom layer) by clicking the upper right corner X.
It’s a clean Windows 7 install, no add. software.
It’s not the “System Busy” or the disconnect-error, it’s like the graphics are freezing somehow.
I have a show (my first show without a surface!) this saturday, and would love to solve the problem as soon as possible.
Are you running it on the Pentium4, 1900 x 1200 res laptop? If so then then you will need a pretty good graphic’s card with dedicated video ram - especially with Windows 7! More info is required about your setup! Perhaps try a lower screen resolution setting.
2 Ideas, first could you provide the model number of your processor, I’m inclined to agree with Richard, Editor is hungry and it might just be a performance issue.
A straight P4 2.2Ghz released Q2 2004 will give an independent benchmark of 279, we recommend 1000 ! You can check your processor model number here for performance:
Second it may be a Java VM issue could you post the output of
java -version
at a command prompt ?
My best guess would be the laptop h/w though, we also play counter strike here, but its an old game, how old is the laptop ?
