Editor
Hi guys,is there anybody that can explane me how to connect my ILIVE to PC by ILIVE EDITOR online?
i will try to explain
first of all check your ip-range. by default the i-live uses 192.168.1.x
x=1 touchscreen
x=2 surface
x=3 mixrack
for example
your pc will be fine when you use 192.168.1.4
next step go to the preferences at your surface, network settings and enable external control.
plug in a cat 5 cable at your surface or mixrack in an ethernet plug.
other side into your pc,
start the editor choose online and the surface, wait a little moment and voila here you are
frank
Thanks so much Frank,
I missed the step of set my surface on external control.I did’nt find it nowhere.
Now it works succesfull.
Peter
