Effects in Outputs
I’m a novice at mixing but have been working on this for awhile so I’m asking for help! I’m mixing for a small 4 piece group each using a different output for in-ears. I can route effects to the in-ears but the effects are still heard when I bring down the out1 say fader level. Is there a pre send or post send switch for the outputs? What am I missing here?
I think the FX screen allows you to do this in its menus. You can set the FX send level per channel. Not at the mixer right now so can’t direct you specifically re the outputs.
On the Config Digital tab you can set the source point for your recordings ie dry post pre or post inserts etc as well.
Hope this assists
Cheers
David
