Effects not working
All of a sudden the built in effects are not working anymore?
I can see by the meter that the signal is reaching the effects, but no effects?
worked perfectly before.
Can someone give me some help on what settings to check to make sure they are not some how muted?
Both master effects are up, all returns are up, and channel mixer sends are up.
DCA?
What do you mean DCA? everything works except the effects.
All faders are up
Is the return in a DCA which is down?
I’ll check it out but I never routed anything to a DCA.
Click routing tab, then select Mix sends tab, you will see mix 1 to 9-10, then LR, check the volume is up or set level to 0db fx will then work, i just got stumped by the same issue after setting up DCA’s… also im on a QU24
@Micktgta
much more likely something on the board got changed than all the fx just failed
you need to verify EVERY setting everywhere to be sure
A long shot but one possible cause that has not been mentioned would be the actual
FX “units” IO patching. When you open up your FX processor on the right hand side there is a front panel/back panel tab.
Hitting that will flip the unit around and let you re-patch the input and output routing
from the normally assigned FX mixes and returns.
Again it’s a long shot but if someone was messing around with the mixer who knows what they could have gotten into.
If you got the top layer with the mix sends and returns do you see any level
indication on the FX return channels?
PAFL the FX send masters and using headphones do you hear any audio?
PAFL the FX return channels and using headphones do you hear any audio?
If you hear audio on a PAFL FX return but not in the main mix go back and double
check that the returns are assigned to the main LR mix.
Note that this was a question from over 4 years ago.
I expect the problem’s sorted by now!
I would hope so!!!
Well at lest it’s good info for the next person having the same problem.
