Effects parameters using mix pad
Just got a SQ-7 and wondered if one can edit FX parameters other than delay times on the mix pad app.
thanks
Get the firmware 3.0 update, then you can edit all fx parameters
Thanks ronnie, I’ll check it out.
I can see that you can edit fx parameters. I dont suppose you can change FX types in the iPad editor? i have a SQ6 with a faulty FX button, that i am waiting on a solution for, however i am unable to change FX Type.
As far as I can see, you can’t change the FX type from the app control. This needs adding to a future update.
