Emellan MIDI extender app for CQ
Hi Keith,
Thanks for clarifying this. That makes sense, and I would obviously prefer to stay within the officially supported MIDI control functionality rather than rely on the proprietary network protocol.
I’m trying to solve one specific issue with my CQ-18T: I would like the FX delay to automatically follow the BPM of each song in Stage Traxx 4.
As I understand it, the CQ cannot receive MIDI Clock directly as a delay tempo source. However, the CQ can assign MIDI Note 48 to SoftKey 1, and SoftKey 1 can be assigned to Tap Tempo.
This made me wonder whether the following would be the best supported approach:
Stage Traxx 4 → MIDI → CQ-18T
Stage Traxx would send MIDI Note 48 at the appropriate intervals, effectively simulating taps. For example, at 124 BPM, it could send three Note 48 messages approximately 484 ms apart, causing the CQ to set the Tap Tempo accordingly.
This would avoid TCP entirely and use only the documented MIDI control functionality of the CQ.
Would you consider this the correct/best way to achieve automated delay tempo control from an external application such as Stage Traxx?
And, more importantly, is there any other officially supported MIDI method in the CQ that would allow an external MIDI Clock/BPM source to control the FX delay time directly?
Thanks for your help.
Best regards,
Lars
Hi @LarsEspen
Yep! That would be a good way to achieve it, and is the way we’ve recommended in the past with CQ, Qu, SQ. You can include an extra MIDI track with a note (to trigger the SoftKey) that virtually taps out the tempo.
Yes, that is exactly what I do In StageTraxx:
Thanks for the reminder. :slight_smile: and great to hear CRA helps you improve the CQ. I really hope the MIDI implementation expands in upcoming updates, thanks!
I ended up using external plugin on loopy pro for the delay.
What trigger my choice is the ability to have a delay FX with ducking (CQ FX cannot)…
I choose Nembrini audio DELAY3000 for its ducking function and the possibility to run 100 % wet.
MIC from CQ is routed into the ipad loopy rpo and sent back to a stereo channel on the CQ that become my FX return.
No problem of latency (100 % wet signal).
I attempted to use the official tap tempo with my CQ… it ‘works’, but it is not very accurate using MIDI + soft-key. Where I really got into trouble was getting the tempo back to my default 100ms (slap-back). Once I set the tempo say to 500ms or so, the MIDI/soft-key tap tempo could not get it back to 100ms, as this was simply too fast to reproduce accurately.
Down the rabbit hole of reloading a FX with default setting; not supported on CQ series.
Down the rabbit hole of reloading a scene; It worked, but now my Gain and Main volume is back to default. Not something I could do during live gigs, where I adjust on the fly. No supported way to mask not updating those specific items on scene load.
Without additional MIDI support, using FX delay in my use case is simply not possible. As a solo musician, moving “up” to another mixer series is plain silly. I use 1-4 inputs on my CQ20 as it is, I need light and small.
As is, the use of the network control protocol is the only thing that got me around the automation limitations in the current CQ series. Hopefully prior to your ‘lockdown’ of the protocol your MIDI implementation gets a serious upgrade. Allow setting the delay directly in two byte MIDI message.
Good to hear that upgrades are the in the pipeline for the CQ series (reading between the lines). Hopefully I will be able to upgrade, else I just keep what is working for me now.
Is this with Songbook or your Raspberry Pi solution? I do my softkey tapping tempo from StageTraxx, which is accurate well within tolerance of song delay. Plus it has ways to send new taps at the end of the song if you want to return to sa the 100ms of yours.
My SongbookPro app can only send MIDI commands, not tap tempo. I am also wireless using wireless WIDI which can introduce extra delay. I use a Raspberry Pi solution for now; would like to remove it from the picture entirely, but it is also needed for my modeler, which has similar issues like my CQ mixers… half baked MIDI support. I must use playwright.chromium on my Pi to do some automations.
I have optimized my gear and cable setup as much as possible, where eliminating even one extra cable becomes an important time saver/variable eliminator.
Communication goes from iPAD ->BLE-> Pi ->WIFI-> CQ20. The Pi acts as a bridge/translator. In the case of my modeler communication; iPAD ->BLE-> Pi ->WIFI-> CQ20 ->WIFI-> Modeler. So I am using the CQ20 as my wifi hotspot also.
I had/have tap tempo working from the Pi to the CQ20 where I can set the temp via tap & soft-key. I just could not get it back to my default of around 100 accurately/consistently. The network control protocol solution/workaorund solved my problem instantly.
Of course not, I mean ”send the MIDI message you have mapped to the CQ softkey that you have configured to Tap tempo” but that was too long. :slight_smile:
Short answer; no… (has to be 20 characters)
As I can understand that the standard midi have not enough resolution (7 bits, 0 to 127) to set a delay time, what not using NRPN (14 bits, 0 to 16384) as all the other controls ?
Is this a system limitation or a commercial limitation ?
Other have set midi clock using two 7 bit pairs, which can also be used to set delay time values from 5-2500. Just need to get it done.
Midi clock with continuous midi data can put trouble into the mixer and it is not intended for live console anyway.
We should not start making the confusion about midi clock and tap tempo setting via midi message.
We want to focus on setting the tap tempo via midi for the FX that have that function.
A single midi message in opposition of 2 midi messages with the required ms value in btw.
Standard 7 bit midi does not have enough resolution.
For example, if the FX setting tempo can be set from 5 ms to 2500 ms, with a 7 bit midi CC would have a step of about 20ms… not accurate.
The only solution is to use 14 bit midi message.
I am not advocating MIDI clock, just pointing out that others have use two 7 bit pairs to set numbers that are higher than a single MIDI cc of 127. There are many examples of this in the wild. There are much fewer examples of setting delay ms timings.
Sorry, I misread your post, didn’t read “pair”.
You’re right :+1:
In the time being, I have updated my online convertor with a “tempo to MS” and Stagetrax 3 midi message formatting.
