Enable TB function on Qu-SB with external Stagebox
In the same way ST2 and MTX3-4 are only accessible on Qu-SB via dSNAKE/USB, it would be ideal if there was a TB channel/bus included in the software for Qu-SB, despite not having a dedicated local, physical input. An AR84 or other external stagebox could be used to access it given external inputs are already freely routable. The would save stealing/borrowing one of the 16 local inputs for this purpose; typically I have input 16 as an announcer/shout mic and use it for TB as well. As soon as you have someone else introducing a band, you lose two inputs, and then it gets a bit tight. The AR84 would serve these ‘utility’ roles well, and it might upsell it to some users like me who use the console for very deployable lightweight stuff sometimes on its own, or in a more comprehensive manner that requires more talkback and monitoring flexibility and more inputs.
