some ideas…
- high and low pass settings
- switches to change the filter characteristics on high and low
- copy/paste/reset on single bands
- fill the graphics with colors (like on the iLive)
some ideas…
For both the unit and qu-pad app,
Having the ability to turn on/off each band in the parametric EQ, similar to how EQ’s in DAW’s work.
being able to type in the frequency, amplitude, or Q using an on screen number pad.
having the amplitude value of the frequency you are cutting or boosting above or below the fader. Currently there is no indication of how much you are actually cutting/boosting on the app.
… another idea, working with the QU-APP, is that it’s a little cumbersome to adjust the Q on the points. Pinching in/out from left to right is great, but I think it would be more ergonomic to pinch up and down. It’s less likely that you will hit another freq node using up and down. Even having a finger on the node and while your finger is at the freq/amplitude, dragging your thumb towards (up) or away (down) to adjust the Q would be more logical and less likely to cause errors.
