exit editor, then mixrack/surface cracking noises
hi,
mixrack, surface and editor are latest version 1.53v
i´m useing a laptop as a spare part, when the suface may power down.
for that in the edito i choose the option to control the laptop with the mixrack (third one). so i can controll the mix if the surface break down!
i connect the laptop via wlan, that work perfectly. but if i close the editor-software (exit the program) there is a loud cracking noise on all channels, even too on the mixbuses!
i didn´t tried it with an ethernet cable, so some one maybe would like to check that?
is that a known issue?
OFFTOPIC:
sorry for my english
Dear sir,
Please contact Technical Support regarding this and we will endeavour to get to the bottom of it for you.
We would be grateful if you would raise a ticket for this issue here:
https://allen-heath.helpserve.com
Many thanks.
support@allen-heath.com
problem solved by using an other access point…
