External Hard Drive Write Speed for 96k Multi Tracking
This may have been asked in the past, but I couldn’t find this by searching. Anyone know what the recommended write speed is for SQ multitracking at 96k? Waiting on my SQ Rack and want to make sure I get the correct external hard drive.
Just get a samsung T7 or better :wink: no worries
Thanks for the info!
We record to an internal secondary drive (not our OS drive) without any issues. It’s an “old” style 7200rpm platter hard drive - certainly nothing fancy.
Strangely enough, if I try to record directly to my computer’s OS drive (which is an SSD drive), I get audio glitches in my recordings similar to what you would hear if you had a clocking issue. But as long as I record to the secondary drive (which is actually slower than the OS drive), then I don’t get any audio glitches.
Edit - this is with Reaper.
I am looking for a portable drive to record straight off the usb port.
The SQ uses a USB 2.0 port. As such, paying extra money for a faster SSD or NVME harddrive is pointless. Of course you might want the robustness of a SSD drive if you plan on traveling with the drive, but don’t buy it for the “speed” factor.
Got it! Thanks. We do travel so I will be looking for a tank.
96 kHz, 24 bit, 32 tracks is 74 Mbit/second so is the minimum required:
96000 x 24 x 32
(A Mbit is normally 1000000 bits, not 1048576)
Months ago I walked into Best Buy and bought the 1TB Samsung “Portable SSD T9” Model MU-PG1T0B. I plug it into the USB drive on the front of the S5, and have recorded many shows in mutltitrack. I always format the drive on the SQ just before using it. I have also found that this drive works great in moving settings from one ME-1 to another.
Awesome! Thanks for the information.
