Extra faders
Does anybody know if the MIDI implementation has feedback so you can connect a Behringer BCF2000 as extra (cheap) moving faders?
Thanks.
Andy
while on this subject i would also like to know if is possible to add a second T series console just as a controller via the network ports.
For example. I already have a T112 / IDR48 system and i need extra control… So i i add a T80 surface, theoretically what is to stop me from manually giving the T80 a unique IP address just like i do with a laptop running editor and hooking into a spare Network port either on the mixrack (but ideally on the T112 surface)
Surely this should work… correct?
I would assume the PAFL would still route through the main console, and no audio would pass through the sidecar but in its simplest form a surface is just a computer running editor with a bit of software controlling the faders and LEDs… right?
A&H… your thoughts please.
Graham
Hi Andy - The iLive does send and receive midi for faders,mutes, DCA assign, name/colour and scene program changes so yes you can use a midi controller with moving faders - provided it can send/ receive the correct midi data. I have developed a custom environment in logic audio to convert the ilive midi data to work with a logic control (LC). This should also work with a BCF2000 if in logic control mode. With the LC bank keys you can access every channel of the iLive and the faders will all be recalled to their current position. My environment also offers some powerful other features when used with a logic/Mackie control - such as LC channel strip naming to match the iLive, a DCA solo mode, custom assignable strips (put what ever strips you need on the LC surface), DCA assignments, direct access to DCA’s , master fader, Scene recall plus 32 independent fader/mute scenes etc. The LC can be used as an extension to the ilive surface or stand alone with the editor/laptop (with midi connections from the mixrack). When using with a wireless Laptop I can also connect MIDI and 2 ch Audio to/from the mixrack over a single Cat5 cable (via USB extensions) to a Tascam US122 sound card. Check out these screen shots over at Pro Sound Web: https://srforums.prosoundweb.com/index.php/fa/25411/0/ https://srforums.prosoundweb.com/index.php/fa/25413/0/
The ilive Midi Spec can be found Here: https://www.ilive-digital.com/Downloads/iLive%20MIDI%20specification%20V1.3.pdf
I am intending to get some video uploaded to U-tube of the software/LC in use but I’ve been to busy to get it done! The requirements to get it to work are a 2x2 midi interface (1 Midi in/out for the LC, 1 Midi In/out to the iLive), Logic Audio (PC or MAc), plus a Logic Control or Mackie control universal in Logic control mode. If anyone is interested in this then let me know.
Graham - Interesting idea of using another iLive surface as a controller -Hopefully A&H will clarify if that could be done.
Graham, we were considering doing the same thing. I hooked a second T112 up to our iDR48 to try it out a little while back. It worked fine, but I only played with it for a few minutes so I don’t know if it would be stable for the length of a show. It makes sense that it would work like a second computer though. . .
Hello All
The multiple surface to single mix rack is something on the to do list, but unfortunately at this time we don’t support it.
It is possible to connect two surfaces to the same rack, but the surfaces will not behave as you would expect. For instance its not possible to select different channels on each surface, as the processing on both desks will be the last channel selected on either desk.
Sounds confusing, but there are a number of gotchas which are not obvious the first time you connect both surfaces.
If you feel this is an important feature, feel free to shout and it may make its way up the priority list !
Have a good Christmas everyone.
Andy
A&H
Hey Andy,
Whilst i dont think this is the most important update, i do think it would be a good idea.
So are you saying it will technically work but say if you select Channel1 on the first surface and tweak the EQ on the second surface it will mirror the changes?
I would think this could be a good point… No matter which surface you are on you can tweak the selected channel, even if its not selected on the second surface.
OK… it sounds like you gotta remember not to grab a handful of eq without first selecting the correct channel (on the correct surface) but we have to do do this anyway so its not a negative point.
Tell me more about the pros and cons of connecting 2 surfaces when you have the time. I am interested in a second surface.
Cheers
Graham
Hi Graham
Other possible issues off the top of my head would be 2 surface of different types, or 2 surfaces of the same type with different I/O cards fitted connecting to the same rack. Either of these will confuse the preamp / trim settings, as each surface informs the rack of its local I/O cards at boot up, therefore the last surface to boot will win. The Rack is only aware of a singular surface, so there is a potential conflict there.
Like I said before its not something we support or recommend. If you have the hardware and want to give it a go and can cope with the oddities, then let us know how you get on, but your off piste so to speak !
Ill make sure the multi surface support is added to the list.
Andy
A&H
I’d love to get hold of the Logic Environment you were talking about if I could. the Prosoundweb links don’t seem to go anywhere interesting :frowning_face:
The request for two surfaces working with one MixRack is usually for the two engineer FOH/Monitors situation. Two surfaces, one brain. Here you would need independent channel selection. As Andy says this is not supported yet but on the list for future release.
A couple things to remember: First, you could use a smaller MixRack as the second brain if you are using a digital mic split to link them. That would make it more affordable and compact. Both racks could live in the same case. Second, you can achieve a two surfaces, one brain system using your laptop as a ‘virtual surface’. That lets two engineers carry out independent tasks at the same time using the one MixRack, for example FOH and monitor mixing.
Hope that helps,
Carey
The links I posted above to Prosoundweb above seem to have a strange behaviour - if you click on them you may get a error or file not found message - however if you then hit your browser refresh button the links then work.
Here’s another link which is to the original article https://srforums.prosoundweb.com/index.php/m/395413/0/?srch=ilive+scene+save#msg_395413
Scroll down to my later posts and you can also find the attached images there.
I still haven’t done the demo video - will try to find time but just to busy most of the time.
I will be interested to see the pricing on the new IDR16 and the iLive R72 surface. The R72 could be the best solution to having a compact FOH set up like the Mackie control/Laptop and custom logic environment I use on smaller jobs.
Pity they didn’t make the screen fold down like a laptop so the unit was much smaller again!
Richard
IDR48/T112
Hey Richard,
very interesting thing. I was thinking about a similar thing - adding a (cheap) Behringer BCF2000 as fader for let’s say vocal, rev and delay or so.
But I didn’t manage to send all 3 strings needed to adress channel, select function (there fader) and send value.
I’m logic user too, so you’re solution seems to be very smart (though your able to switch between differen channel which one can’t even do with a PL6!).
But I’m not very familiar with the environment thing. So would you give me some hints?
This are my main qustion:
  • I asume you create a “dummy” audiochannel in Logic for every iLive-channel you want to control, so the Logic-Control can handle the channels via these dummies ?
  • If so, how can an audiochannel create needed mididata (or even basic data, that can be used for a transformer)
  • How can you sent all 3 strings needed? Is it just a macro including 3 transformers?
I know it needs a lot know how to create such an enviroment like you did, but I would be thankful if you can share a little bit of your knowledge.
Regards Peter
IDR48/T112
Hi Pete
Yes you are correct - the logic arrange window needs to mirror the channels on the iLive - or you can customise and have whatever channels/ names you want. The environment is very complex and uses sysex to send the correct midi strings. It would take some time to explain everything so I will just send you a copy of the environment(if you reply to my email). If you are bored and have the time you can study my environment to see how it works! There are set up instructions included on screenset 8. I would do a backup first as it’s very easy to mess it up with a click in the wrong place! It should work with the Behringer - I think the BCF can be put in a Logic emulation mode? The Mackie is the way to go though as you get channel names/values and direct quick access to DCA’s, Fx Sends, Returns, Buss’s, master fader etc when using a mackie control’s global view keys and bank change. It has over 128 channel strips! I’ve also just added lighting control using the free Abuelites software and a supported computer DMX interface (I have a Enttec ODE Artnet node which can also share the CAT5 iLive network). Just hit the MIDI Tracks global key on the Mackie and you have control of Abuelites 20 programmable subfaders (each subfader scene has 512 DMX channel access). Lighting and sound on one control surface! The demo video is…being edited and will be here someday. Trouble is I keep updating the environment with new features so the video is already way out of date!
Cheers
Richard
IDR48/T112
I finally have the LC-iLive video done. Check it out to see how a Mackie Control can be used as additional faders/mutes, scene control and even for sequencing fader movements with the iLive. The Mackie has banks and quick keys to access all 128 iLive channels,FX,DCA’s and mix faders. It uses a Logic environment to interface between the computer and iLive MIDI I/O and is designed to run in conjunction with the editor software. Let me know your thoughts.
https://www.youtube.com/watch?v=DhMbfmfpPoQ
Richard
IDR48/T112
That’s what I was talking about!!!
Are you making this available somehow?
Richard,
That is awesome! I’m relatively new to Logic having recently made the switch from Pro Tools so I can see that I have a lot to learn about not only its music creation capabilities but also show control potential! Two quick questions:
Do you know if Logic Pro 9 for Mac has the features to accomplish this (It seems that the 8 release changed a lot about the program)?
Is it possible to still acquire an old Logic 5.5 or later for the PC, and can you direct me to a source?
I bet if you posted your environments online with a donation box you would see some return.
M. Jason Pruzin
Sound Designer/Engineer
Arkansas Repertory Theatre
quote:
Richard
IDR48/T112
Respect!
This is awesome, it shows the growing potential of iLive products. I hope that our friends at A&H also see that it definitely won’t harm their business if they would come up with an API to even go beyond the current possibilities of MIDI control.
Wouter
My prayers have been heard, Dante is coming!
This should work on Logic Pro 9 although I have only tested on 7 and 8. As it is an environment it should import no problem otherwise no older logic environments would work on pro 9. Sorry - I have no idea where you might get a PC version 5.5 other than maybe Ebay? Yeah I would like to post online with a donation box system - not sure how to go about that though. Anyone have suggestions how to do that? This environment took me weeks of work to create and I would like to be able to offer tech support to anyone who has donated as well as to continue to develop it further. I’ve already added lighting control to it since the video was shot!
Of course if Allen and Heath/ iLive were to directly support the Mackie Control protocol then there would be no need for my environment and a MC could connect directly to either the mixrack or surface without the need for a computer in between.
Anyone who wants a copy then email me and advise PC or Mac version: audiodyn@es.co.nz I will be away for over a week though so be patient. I request that people don’t distribute it openly as it is still a work in progress and I plan to release updates to interested people who wish to be on my environment email list.
Richard
IDR48/T112
quote:
Originally posted by pete.j
Hey Richard,
Regards Peter
IDR48/T112
Use the “LEARN” function. It does work.
Wouter
