is there any way to adjust the fader response time? working with a t112 and there always seems to be a slight lag whenever i adjust a fader.
Can you explain a little further? What lags when you adjust a fader? You move a fader and the audio volume level doesn’t respond?
I adjust a fader, and there is a definite lag between the fader movement and actually hearing the change. maybe a half second or so.
quote:
Originally posted by d0ntpanicI adjust a fader, and there is a definite lag between the fader movement and actually hearing the change. maybe a half second or so.
Humm???, I remember that this was one of the first things I checked out before even contemplating a iLive purchase and never had the lag thing on my R-72…have you tried disabling/enabling multicast settings in the setup menu? these have been known to create some lag in response time for faders /meters etc…other than that I would suggest something is not right with your particular unit/installation and therefore you should contact A&H tech support and submit a ticket if you haven’t already.
RayS
R-72/iDR32/iPS10
