Faders assigned to FX Speaker Matrix outputs
I use the built in speaker Matrix FX processor to run my FOH.
This works great except that, if for example I were to run a 5 way foh matrix i.e. L delay, L,C,R, r Delay, I find I have no gain/fader/level control of the outputs, as the inputs are simply Left main and Right Main. Even the centre is unassailable to the centre output of the Spkr Matrix. Am I missing a trick? I see it is possible to add delay times to each position but it does not seem possible to control individual position levels.
Because of this I end up using a matrix to supply my L&R delays just so I have some level control at the desk. The downside is of course that the output signals to my delays are now not x-over processed and this is the same for my centre which is also fed from Main Centre.
Now I know I have processing available via the MTX to GEQ/PEQ, but there is no HPF in the MTX!
If I am not mistaken and I have not missed something - I suggest that this becomes a feature request - that output per speaker not only has a delay assigned but also a level control much like the virtual fader controls in the multi-band compressors.
Mark
(aka Fergie)
I haven’t played with that, but can’t you patch Speaker processors output to direct input of MTX?
dddff
Hi Mark,
I wouldn’t use the iLive Speaker Matrix for delays. The way it works, an LR signal is spread across multiple speaker stacks across a wide stage front. Far L and far R are not copies of LR, they are the extremes of the PAN image. You’ll get all sorts of phase issues if you were to use these for delay stacks.
https://ilivefx.allen-heath.com/spkr.php?t=i
Thanks Nicola - that’s handy to know.
That’s a possibility dddff I will investigate - thanks
