Faders moving without being controlled
After updating to v1.1 the console has had issues with fader number 3 on bank a being moved without any control input. It doesn’t matter which layer the bank is on, the level of fader 3 is the same for all channels assigned to that particular fader. I’ve checked through custom control to make sure that nobody is controlling those channels, and I’ve also confirmed that nobody is on MixPad or OneMix, so unless I’m missing something I feel like I’ve checked all possible variables, and I’m fairly confident that this isn’t user error anywhere in the chain.
Did you contacted your dealer/distributor?
Maybe for a test try rolling back the firmware and see if the problem goes away.
Or try a firmware re-load.
