Hello!
Soon I will be using the SQ5 for a live recording session in the studio. The SQ will be used for the monitor mix (for musicians) and as audio interface.
After each take, i need to recall input patch preset (inputs from USB) to listen to the recording. Afterwards, I need to recall the input patch preset (inputs from stagebox) for further recordings. Guess I will have to recall the presets hundreds of times ?
Any ideas to improve this workflow?
Is there a way to quickly change the input patch preset? (SoftKey, MIDI Commands from DAW, etc. …)?
Using anoter layer/channels for USB returns is not an option, since I want to hear the recodring with the same processing when using it for monitoring.
Thanks in advance!
