Hi, so here is my feature list request.
1: Extend function on input faders to push onto master section when needed as per midas pro console.
this gives extra bank of faders on one surface when needed.
2: Population groups are also good - midas again.
3: virtual soundcheck. either the ability to push one button and set to alternate inputs ie digital dante connection and then back.
4: DCA and Group spill - this has been mentioned.
5: in i/o the ability to tap and sequence a bunch of inputs in line. not one by one. it is too slow when you want to change 30 channels.
6: obviously mute groups. - mentioned several times.
7: the meter bridge on both screens. to be able to tap a channel there and go to its settings.
at the moment if you are on another bank doing something, this can be a quick way to get to an input or output overview.
8: it would be good when scrolling through DCA and group and matrix masters etc and aux for that matter, when you look at the input strips, it will say aux and DCA and group. but not which one it is associated with in the scribble strip. you have to look up to overview on the masters to see what is in each output.
9: The VGA output. not sure why it is there to mirror left or right when you have a 12" in front of you.
so how about you give third option to set to only meters . or scenes. or a selection based on a button.
This would be invaluable when running scenes and seeing the cue list without changing pages. or meters without scrolling
I have only been on the s5000 for 2 weeks. coming from both Midas and Venue.
I got to say I see a lot of potential. and so far it is looking good.
It has changed my mind on AH…
Another feature needed is a default button for setting faders etc. and a multiselect would be good as well
To set all your faders to 0 like venue does. to hold a button down and tap select to reset the fader
Another request.
After assigning my custom rotary buttons to an aux mix for example. it shows Aux on the scribble strip but not what Aux it is assigned to.
I also find this with DCA, group, and other assignable things.
You do no know what you are on as the scribble strip does not tell you. just that you might be on an aux, or a dca, or a group.
it would be good for the scribble strip to show extra detail. please.
Hold the Reset
button and nudge a fader towards 0 dB or -infinity.
Hope this helps
Thanks Jeff. that worked well.
Appreciate the quick fix.
any idea on some of those other things?
David
If you hold the Setup
button while in the I/O screen and touch the I/O assignment area, you can turn on “Only assign when the ‘Assign’ button is pressed”. In this mode, you can hold an on-screen Assign
button, and drag diagonally to assign I/O. I don’t use this myself, but I do like to set the I/O screen to use the full screen, and enable ‘radio’ mode (‘radio’ as in radio button, as opposed to the radio broadcast application).
You should be able to achieve this using the scene system and a soft key. You can allow it to use just one button by using two scenes that change the function of the soft key so that it loads the other scene. These scenes would have their recall filter set so that everything except the relevant soft key and the input routing patch bay are blocked (this is easily achieved by starting with the block all
button).
You may also be interested in any reports on V1.2 that come back from PLS frankfurt.
Thanks Jeff.
I appreciate the details. I will play around with the only assign section in i/o.
I think i did try this, but i still had to tap each square to get it to set. will have another look.
The scene and alternate inputs, potentially could work, bit if we are doing a lot of different shows, it could be time intensive if inputs are not one to one .
we thought of this, but it would be good for future options to have a button that will just switch to alternate inputs.
the hazards here are that yes i can build a scene so i can go to my digital io from Dante to playback, make a stack of changes to the current scenes, then have another button to put the i/o back. remembering to make sure those options are safe again. it is time consuming and also can lead to potential disaster. if i was working on a theatre production of 100 scenes.
i am waiting for PLS to start. and will be watching for news of 1.2
I know mute groups is a desperate item needed.
Hi Davo
If your two virtual soundcheck on/off scenes have a recall filters set to only recall the input routing patch bay and the one softkey they use, you shouldn’t have to use any safes or update anything else unless you ended up changing the ‘normal’ input routing patch bay. Even if you did change this, all you would have to do would be to select your ‘normal’ input routing patch bay scene, and press update
, to load it with your revised input connections.
I realise this is not quite as good the ‘alternate input’ function you suggest, but it seems that if done right, you could get 90% of what you’re after using scenes.
Thanks for the detailed explanation Jeff.
I am still trying to understand this. so for example I have 50 scenes created for a show.
I have recorded the multitracks off via Dante.
Now I want to play the tracks back and replace the inputs.
So I create another scene with recall filters set to recall only input routing
play back tracks and make any changes i need, save the scene and all is good and set.
then press the button to change the inputs back to live.
what if I needed to scroll through a bunch of scenes. do i need to enable this button each time.
Or do I set this into the initial scene ie a base scene where the inputs are not recalled either way unless the button is pressed?
Hi Davo
Sorry, I’ve made a mistake here! When I’ve been talking about ‘Input Routing’, this is actually the wrong thing; what you need is ‘Patchbay’ in the ‘Other’ section of the recall filter.
So my idea now becomes:
- Block
Patchbay
in all your 'normal' scenes. I can see that this might take some time for a big show.
- Make a scene with only
Patchbay
and one soft key unblocked, with your normal I/O patching.
- Make another scene with only
Patchbay
and that same soft key unblocked, with the inputs taken from your I/O port.
- Use these two scenes as your switches. If it works, set the soft key up in each scene to recall the other scene.
Sorry again for the confusion!
thats ok Jeff. I appreciate the update.
what would make my life easier right now is the editor.
I can do this from home. I am now using the dLive every day at work. and it would be so helpful to be able to work on this stuff at home
Dave
hey Jeff.
seeing as how the dLive editor is not available, I downloaded the GLD editor and set it up
After a little confusion i have it working on one buttong.
The trick with the 2 scenes is to get the button to recall the other scene lol
I did it the other way first and wondered why it wasn’t changing
As long as you have the patchbay blocked on all normal scenes you are good
So what you would do is go through and setup all your patching and make it correct.
because if you change something it could mess it up
then create the 2 VS scenes, one normal and one alternate inputs.
Then create your base scene for productions with patchbay blocked.
works a treat. for now lol
hopefully down the track they will simplify this.
because it has the potential to go awfully wrong. lol
Jeff another quick question on this. would there be any issues with the levels when they come back from main inputs to digital inputs, will there be any gain variations.
I am seeing the gain rotary moving when switching between scenes for main and alt.
We had this issue on the SC48 venue. where gain from alternate inputs was 6db higher
David
Hi Davo
The ‘gain’ rotary moves because for a remote input, the ‘gain’ is actually the trim control, since there is no real pre-amp in this case. So what you are seeing is the rotary function changing from showing you the gain you had on the pre-amp, to the trim applied to the channel (which is probably set to zero dB).
Hope this helps
cool. so switching between live inputs and recorded ones should not have the gains out of balance. one hopes.
good to know.
I have not heard anything from PLS yet. apart from the release of the new mixer.
are there any bits of news on the Mac editor for dLive and the 1.2 firmware.?
Another feature request would be more rack space.
coming from Avid where I have racks for days, where I can insert 7 band PEQ over each output
or even double 7 band PEQ over a ingle output for really troublesome applications, I am struggling with the 16 rack spaces.
being able to insert on A and B insert is cool, but you can only seem to do it from a mounted rack.
and in large scale theatre productions with loads of open mikes and condensers, this type of capability is necessary.
Unless someone knows a way of inserting a tool without having it mounted
