Sup guys
My setup
Qu16
Two dsr112
One dsr118w
Looking to get another sub in the future
I mainly dj and do karaoke parties for fun
I bought the system for karaoke for home use but ended up doing some gigs for fun but people are willing to pay me to do parties…especially karaoke…
1.)I’m doing aux fed sub…since my tops are crossed over at 125 with the hpf on…so for the sub I just use the geq for the mix and bring all faders above 125 down right?
What if I want to do it at 80hz? Turn off the hpf on tops then use the geq for the LR mix? Will this mess up the recording if I decide to record? Or would it just take the frequency out on the LR channel?
2.) monitor I have it on mix 1. How do I send fx for the vocal to monitor?
3.) eq room rta flat response…I’m confused…why do we want to get a flat response? When I goto my rta meter a lot of it peaks out and it isn’t flat lol…so do I need a rta mic then pafl that channel to get a flat response from the rta mic? I guess the rta for like the karaoke music or MP3 etc doesn’t matter? Is the rta meter really for ringing out feedback? And to use to tune a room with a rta mic and pink noise that the board has?
What if I want to cross it over at 80hz?
Oh so the way my setup is now I don’t have to use the geq on my aux fed sub…since it doesn’t play anything above 120hz…I was going to see if it’ll sound better crossed over at 80hz or 100hz…not sure if the geq has 100hz
Ok I’ll try the monitor again
To make it short: The HPF/PEQ/GEQ can not replace a proper crossover, the GEQ particularly does not cut frequencies below the lowest band, there is (sadly) no HPF in the Mixes, the shelf PEQ isn’t steep enough and only drops to -15dB. Any USD150 analog Xover provides better results, if a flat frequency response without phase problems is your target.
More to read here: How to hookup subwoofers to QU 24?
Some plots can be found here: use equaliser to put low pass filter in place
Should I get a Driverack pa2 or a 360?
Or should I just get a decent crossover? Any good ones for $100?
I use the PA2 or 360 on my installs. Work well. Don’t buy a real cheap Xover. PA2 is very reasonable. I have a wifi router I use to set it up with their free app.
With a pa2 can I still do aux fed sub?
I know the 360 can because it has 3 inputs
No, but you could setup the crossover to be a mid high then feed your subs direct if they have a low pass filter. Or get one of the processing amps like QSC or Crown have and make it a band pass filtered amp. I use powered subs a lot which have built in LPF. The 360 would do that.
I’m using a PA2 as well and find the crossover very good and easy to use. I do find though that when I try to set up in a venue that has people already in it usually tells me that the background noise is too high and won’t run some of the Wizards.
So with any Driverack u would need one per main and sub? So if I get a 2nd sub I need two driveracks?
Not sure I understand your question but you shouldn’t. You really only need one aux fed sub output then feed a crossover or bandpass amp and just mult or parallel to a second sub. Some of my installs have stereo subs but only because of how I set it up. Really not needed. LF is so omni-directional it doesn’t matter.
