Finally Happened
Just a frustrated rant here.
After a few years of having perfect success recording from my SQ onto externally powered SSDs, a friends SQ failed to do that last night for some reason.
For years, there has been this constant stream of discussions about SQs failing to record to different media. USB sticks, thumb drives, Samsung drives, extrenal drives and for years, I have found and believed that externally powered drives were the solution. Wrong! I was so angry last night watching the error rack up on the display.
I am now going to stress-test all my drives, as the same sort of drive/enclosure set up with a different SSD performed perfectly for the second half. Makes me fucking crazy that I can’t rely on this feature to do what it should. Quick fix A&H? Send all owners a little USB plug and some epoxy glue. I am taking my MBP and Reaper to the show today. Pretty certain that won’t fail.
Why does the problem still exist A&H? It’s a bummer to go to my client and say “There were computer errors in the first half. The back-up 2-track will need to be good enough. Sorry”
D.
Did you check the compatibility of the SSD with your SQ before the gig? I check every cable and every piece of equipment and often take spares.
It is very annoying when things that are supposed to work together but do not. It is worth taking the time to check things before you leave for the gig.
My prep for gigs is pretty rigorous. This same drive works fine on my SQ, just not my boss’s. This discrepancy is perhaps while so many SQ users have such different results in trying to use media for recording off the SQ.
There is definitely a reoccurring issue with recording to USB media, and A&H has clearly failed to address it.
D.
I must concur,
A&H has made commendable efforts in simplifying some of the software used on their desks. However, the highly publicized record to USB/SD functionality truly warrants significant attention and dedication to ensure its accuracy. Such issues can lead to a negative perception of A&H among users and their clients, regardless of the excuses provided.
The USB dilemma for the rest of the computing world has been a non-issue. To be precise, digital desks are essentially computers equipped with unique sliding knobs instead of traditional keyboards.
A&H, MUST prioritize the resolution of this USB issue or drop the option and push the desks as an interface for the DAW of user choice.
You know the old saying,
“Sh_t or get off the pot!”
I can’t believe that people still try to record directly to USB drives - especially given the known problems.
I would recommend that you get a computer (it can be cheap/low spec’d) and install Reaper on it. Then you can record as many tracks as you want, reliably, and without any hassle. If you use something other than a laptop, you don’t even need a keyboard/monitor set up for the computer. Just set the computer up to start Reaper with your selected template loaded and start/stop recordings through softkeys on the console (via midi) or use the browser interface (on your phone for example) to start/stop and monitor the recordings.
