can you please look at making the frequency knob finer in its adjustment? if you use the jog knob when selecting the frequency
it works great! it would be awesome if it the main freq knob could respond like that
+1
Yes to finer adjustment on the touch and turn - especially delay, I need to use the iPad to move in tiny increments! so it can do it, just not on the surface.
I get what they’ve done with the EQ. We shouldn’t need to look to EQ because it should be in the ears, just like using an adjustable PEQ on an analogue desk. Thats why they’ve made it move a lot with a small touch I think, so we can hear a difference in a tiny turn of the wheel. Then when we need to actually do some micro-surgery on the sound we go in and use the touch and turn. I like that approach and am trying really hard not to look at the graph, as my OCD likes to make nice looking EQ curves too much
+1 finer adjustment in the EQ and Delay
Hello, it is quite old topic, but seems still rough adjustment on the peq knob on the surface. When using the jog knob then the frequency can be fine adjusted. For me it makes the direct frequency knob useless, as i every time need to select the jog knob to do the fine adjustment. But may be I have overseen something or other people work differently?
+1 this is very annoyinng
Hello @jofpet, just a question for understanding. Does the +1 means a vote? But the vote number is still 1. If you want to increase the voting/ranking, you need to press the vote button on top. Thanks.
ahh, thanks for the notice
At this point I would like to add that the possibility to deactivate such an option would be absolutely necessary.
Hello @SQuser , why you want to add such option to deactivate? For the toggle knob it works quite well. If you turn fast, you can move fast throug the frequencies. If you turn the knob slow you will have a fine adjustment. If this would be copied for the dedicated EQ Frequency knob, why there is a need to make this optional?
I definitely don’t want a controller with dynamic behavior.
Alternatively, I could easily imagine every (frequency) change being automatically synchronized with the yellow touchscreen rotary, which would then allow for immediate finer adjustments as needed.
