Firmware Upgrade Question...
I work with a GLD 80 desk at my church, and discovered that we are still using the v1.1 firmware. I am going to upgrade to the 1.3 firmware this week. Do I need to install v1.2 and then 1.3, or can I install 1.3 directly?
Also, in preparation for updating the firmware I saved our current show. Do I understand correctly that all library items also get saved with the show? I am not the only one that uses the board, and I want to make sure that all of the library items get saved as well. We have a lot of them, and I don’t want to have to save them to USB individually.
You can install the new firmware directly without doing the v1.2 step! Save your actual setup in a scene as well as the whole show! For a backup you should save the show as well on a USB-stick! The Library will be saved in the show as well!
Peachy…I thought so, but wanted to ask to make sure. Thank you for the response.
