Firmware upgrades....
I am hoping to give some info that may go into one of the firmware rev’s…
on the routing page for AUX/FX/etc…can we get a select all button and maybe a selection for Pre-fader? right now I have to do each one individually.
on Record. can we get a track mark button? right now I have to stop and start the record for each track.
SPDIF setting is low. can we ramp up the volume a bit? or allow us to do so???
Just asking…
[:smiley: ]
I’ll bee glad if compressor default release speed will be slower, than 500ms.
20.08.1980
You can set global pre/post fade using button combinations on the surface. I don't have my GLD in front of me, but this is documented in the manual and the on-screen help file.
If that is made similar to iLive, then you select AUX mix, then hold green pre/post button and press green select of selected AUX, now it should toggle all inputs sent to this AUX from pre to post and vice versa.
ddff
