FOH MONITOR MADI Setup
Does anyone know if I can use redundant MADI connection between FOH and Monitor console.
Using 1 x IDR-64 w. MADI in port B for stage,
and 1 x IDR-16 w. MADI in port B for FOH.
And have both monitor and FOH use the outputs in the IDR-64.
AND have a MADI feed for broadcast/recording truck.
Oscar
Parashoot
Sweden
Hi Oscar
Yes this is possible if you set each MADI module to Redundant mode. to do this go to touchscreen - Mixrack setup - Mixer Preferences Port A/B setup and press redundant mode on the MADI card in each mixrack.
Yes you can do a digital mic split using MADI sending all your mic inputs over PortB to the other mixrack.
To do your MADI recording use the MADI Aux BNC. 2 options:
1: Set the module recieving the mic channels to ‘IN 1 THRU’ this will then copy and output all audio coming into Link1 on that module.
or
2: Set the module sending out the mic channels to ‘OUT1 Mirror’ this will mirror the audio being sent out of Link1
Hope that helps
Regards
Sam A&H
Can the FOH guy send his L&R thru the MADI down to stage and take it out from the monitor/main box.
Best Regards
Oscar
Parashoot
Sweden
quote:
Originally posted by Oscar Söderlund
Best Regards
Oscar
Parashoot
Sweden
I’m not sure I understand the question. The FOH L&R would generally already be at the stage, right. If you’re asking whether that can be omitted from the monitor MADI feed, I believe the answer is yes.
Hi Oscar
Yes it is possible to send main L&R from FOH via MADI portB to the iDR64 on stage. as long as you have spare MADI channels and outputs on the monitor surface or mixrack.
Hope that helps
Regards
Sam A&H
