forgotten thing ......
uuh the mean swiss found again something
  • in pl-6 edit the “mix/sel/pfl/afl/” combo is missing - gotcha hähäh
pleaase fix it or tell me how to put it in
  • and again : add to the above mentioned combi a scene recall- why?
well: we have a t80 now in one of my bands we run 10 in ear monitor-auxes
with my pl-6 connected (i know - to the rack) i can assign 10 softknobs to recall the appropiate aux “mix/sel/pfl/afl/” - if this would include a scene where only the strip assignments (and of course the pl6 settings) are stored i have the surface changing to that specific aux - the mix is selected - it is pfl -
to make things short:
one button and i am on the guys monitor a real mean quickoe!!!
no layer changing no selecting just one button
pleaase
cheers
dave
allen&heath iLive-144 /idr 10 / idr 48 /dante (i want midi in dante!)
Hi mumu
quote:
- in pl-6 edit the "mix/sel/pfl/afl/" combo is missing -
The “mix/sel/pfl/” combo is only available when you plug the PL-Anet device into the surface PL-Anet port i’m afraid.
quote:
- and again : add to the above mentioned combi a scene recall- why?
Thanks for the feedback will add this to the feature request list.
Regards
Sam A&H
to understand this right: in the surface PL anet is more sophisticated ? because it is a different computer?
please explain
this is a show how it is ment to be
https://megapeng.com/T80.rar
a workaround would be having the mix / sel/ pfl stored within the scene i recall
wich i havent figured out so far ( i believe it is not possible)
cheers
dave
allways latest firm and software
iLive-144/t-80/idr-10 /idr-48/dante/pl-6/eyepad 1/belkin router/
Hi Mumu
The functionality of the “mix/sel/pfl/” combo was not implemented in the Mixrack PL-Anet port because when running the system without a surface connected there is no need for the Mix and SEL functionality due to there being no surface to use these functions.
No i’m afraid iLive does not save Mix/SEL/PAFL state in a scene i’m afraid.
You could assign 1 softkey button to PAFL a Mix then another button to recall a scene with Strip layout and PL Functionality not the 1 button system i’m afraid but a 2 button system
You could also use 1 PL-6 button as a scene recall layer function that toggles between layer 1-2 which will then give you ability too have more than 10 mixes on the PL6. Use the static LED function to let you know which layer you are om e.g. green for layer 1, amber for layer 2.
Would that help at all?
Regards
Sam A&H
yep thats the one, thanks - sometimes a solution is standing in front of one waving a big flag but one (in this case me) doesnt see it[:wink: ]
cheers
dave
