Hi all,
I’m running into a strange networking issue with a Fourier transform.engine in an Allen & Heath dLive setup and I’m curious whether anyone has seen something similar.
My setup is:
- dLive Surface + MixRack connected via gigaACE
- Dante card in Surface
- Dante card in MixRack
- Fourier transform.engine
- KLANG
- MacBook running transform.client and Dante Virtual Soundcard
Originally, Dante/control were on the same 192.168.1.0/24 network.
The problem is very specific:
When I connect the MacBook directly to the MixRack NETWORK port, transform.client works perfectly:
- plugin control works
- meters update
- plugin GUIs move correctly
- visual feedback is normal
When I connect the MacBook to the Surface NETWORK port, control still works, but the plugin GUIs / meters stop updating properly.
I can move parameters and hear the changes, but the visual state in the plugin window becomes stale or frozen.
The same happened when I connected through the Surface Dante card with the Dante Internal Network Bridge enabled.
Dante audio and clocking are completely stable, including audio through the Fourier engine.
I also tested with:
- DVS stopped
- Dante Controller closed
- Mac connected directly to the normal Surface NETWORK port
The issue remains.
Ping from the Surface side to the engine is also clean:
- 0% packet loss
- roughly 1–2 ms RTT
I then made packet captures.
Direct connection at the MixRack shows a large, bursty UDP stream from the transform.engine to the Mac, with lots of packets around 1088 bytes.
Example:
192.168.1.209:50382 -> 192.168.1.234:64887
UDP length 1088
The source/destination ports are dynamic between sessions.
Over the Surface → gigaACE → MixRack path, normal TCP control and lower-rate UDP traffic still pass, but the large UDP bursts appear incomplete / disrupted.
This matches the real-world behavior very closely:
Control OK
Audio OK
Engine reachable OK
GUI / meters NOT OK
So at the moment my suspicion is that the transform.client GUI / visual feedback uses a fairly bursty UDP stream and that the dLive/gigaACE network tunnel does not handle this traffic transparently enough.
I’m now testing a cleaner setup with Dante and control completely separated:
Dante network:
Fourier PRIMARY
KLANG Dante
dLive Dante cards
DVS
Control network:
Surface NETWORK
gigaACE
MixRack NETWORK
Fourier CONTROL
KLANG CONTROL
with the Internal Network Bridge on both dLive Dante cards disabled.
Has anyone successfully run Fourier transform.client through the dLive Surface/MixRack gigaACE control network?
And more specifically:
- Is there a known bandwidth/burst limitation for generic Ethernet traffic over gigaACE?
- Has anyone seen UDP-heavy applications behave like this?
- Is the dedicated Fourier Control port the recommended way to run transform.client in a dLive environment?
- Any QoS, MTU or network settings that helped?
I have PCAPs from both the working direct-MixRack connection and the failing Surface/gigaACE connection if anyone wants to dig into them.
