Does the GLD 112 have a feature that displays an active frequency graph for a selected channel or DCA for EQ use?
Tim
Tim
Press the Select button for the signal you want to view. Press “Meters” then the RTA tab. you will see a 31 band frequency spectrum of the selected channel.
Thanks Steffen R and beartech. Beartech’s answer is more what I’m looking for. So it’s not possible to see the frequency spectrum while you’re doing the EQ?
Tim
in GEQ yes in PEQ not at the moment
Thanks! As a follow up question, When I select the processing menu, PEQ is an available option, GEQ doesn’t have a tab. I’ve tried pushing the GEQ Fader Flip button, but nothing happens. Is there something else I need to do to activate GEQ? I’m on a GLD 112 BTW.
Thanks again!
GEQ only in Mixes
Alright, thanks!
A way to watch the RTA and adjust the PEQ is to use an iPad the make the adjustments.
Using the GLD app, or another?
