Frozen faderbank
My setup:
C3500 DM48 , use this as a monitor desk ,
8 outputs for wedges 12 outputs for six stereo IEM mixes,
linked faderbank left and right and programmed my softkeys to recall the different mixes.
Yesterday suddenly the automation of the left faderbank failed while right side was working fine.
I use about 24 scenes during the show for almost 25 shows with no problems
When I press a softkey to recall a mix the left fader bank stayed in the position of the previous mix and the recalled mix got the same levels
as the previous. The audio on these faders worked well only the automation failed.
At the moment this happens the only thing I did was recalling a next mix bus for PFL
What I did to fix it :
Recall a previous scene, No result
Recall a basic setup start scene, No result
Recall a another program file, No result
Startup the surface again , No result
Startup Mixrack and Surface and recall my Monitor file now it works fine again.
Can anybody tell me what went wrong ?
