Fx edit window with sel button
Every time I want to edit a fx unit from my rack I automatically press the select button like I do when using the dLive or iLive.
I find no soulution how to make it work that way. Anybody know if there is any hidden enable window for that feature?
I think that this missing select and edit option slows down the workflow immensely, so any workaround would be awesome.
The second option I thought about was to bring the edit window on softkeys which is improtant if you want to quick edit any multibanddynamics in the fx rack. I also did not found any solution to get this work.
Thanks a lot for your help
Paul
FX Edit windows on soft keys would be great.
