I have not been able to figure how to take 1 FX bus send and route it to multiple FX engines, inversely you cant route a Aux to the FX engine and have it continue to return in a FX return channel strip.
Any thoughts?
Any thoughts?
What do you mean by route it to multiple FX Engines? Like, send on FX to multiple FX?
I want to take FX Bus 1 and send it to FX engine 1 and engine 2 for example, you cant do it, it only lets yo assign the matching FX bus number
yes that’s right
it is like it is
FX send assignment is fix
you can route an aux to more than one FX slot
You should post on feature suggestion. They seem to listen and one of the customer support people said delevolopers regularly read them.
I will add that you can assign FX sends and returns to DCAs.
I used to route a single FX send to multiple FX effects with an X32. I did this with vocal effects for example and it provided a single fader (FX send) to quickly pull the effects out while still giving individual volume control over each effect using the returns.
Once I realize I could assign the vocal FX channels to a DCA, I have my single fader back for volume control.
