FX ideas and routing Questions ?
1 - will you integrate new FX in the future ?
  • Disto, Fuzz, overdrive
  • Multibande Compresseur
  • Deeser
2 - is it possilble to assign groups to the L/R ?
3 - there’s a SOLO IN PLACE, CLEAR SOLO ? I not find this options
Regards
Greg
GL80 / AR2412 / AR84 / DANTE CARD / Protools 10
2 = Yes
3 = Clear solo (PAFL) is on softkey 9, if you are running the newest firmware.
Willy
FOH-tech.
GLD-80
AR2412
AR84
Yeh thanks Willy
where is the function for assign groups to L/R ? , I can’t find it… grrrrr [:frowning_face: !]
Clear solo it’s Ok ,
No SOLO IN PLACE mode in this console ?
Press “MIX” on the Main L/R channel, then press and hold down the “assign”-button (located between the two fader-banks) while pressing “MIX” on the group you want to send to L/R.
You will then se “ON” in the group name/ch-window.
As far as i know there is no SIP, but you can P(A)FL the signal by holding down the “Sel”-key for the preamp, the EQ, comp and so on, to monitor the signal in various places of the chain in your headphones.
It’s possible that this signal can be routed to one of the outputs, but i have never tried it :smiley: Anyone else?
Willy
FOH-tech.
GLD-80
AR2412
AR84
