hello allen & heath family
we have an SQ6 in church, and i can’t figure out how to send an fx to one of my aux.
do you have any idea how its works?
thanks for your help
Select the aux/mix you want to send the FX to, just like when you
select the aux and then bring up channels you want to send to that aux/mix.
With it selected go to the FX return channel of the FX you want to send
to the aux/mix and bring up the fader as you would on an input channel.
You can also select the routing screen menu and then select the FX return
and then use the screen menu to adjust the aux/mix level.
thank you for your help. I noticed that this way the effect is sent to LR and AUX. is it possible to send only reverb on aux 8 but not in LR?
On the FX return channel in routing, you can turn that channel off regarding LR
On the layer with the fx returns, when on LR press the assign button to the left and de-select the fx return.
(the select button will turn off then)
thank you for your help it works!
