FX on GLD80
So i have 8 fx saved on the board. I am nnot liking the fx that i have. However ii cannot seem to figure out how i can change the fx. When i look at the faders there is only the first 4 fx that i chose. When i go to the fx channel, it wont let me delete the ones that are there in slots 1 thru 4. How can i change the fx and swap out the ones i dont like for the ones that i do like?
Go to FX menu, select desired FX, press Library, select desired FX preset and select Recall.
If that doesn’t solve your problem, go to Setup/Config and make sure you have configured your FX outputs correctly.
Make sure you have all required FX send / return channels assigned to fader strips. Template shows typically have only 4.
From page 16 on of the user duide is explained what is in the template shows.
https://www.allen-heath.com/media/GLD-Chrome-User-Guide-AP9989_2.pdf
The documents are worth reading… btw it is integrated in the mixer behind de “?” in the right corner of the screen
