Hello,
I wonder about:
- is the FX processor Stereo In → Stereo Out (or Mono In → Steareo Out)
- Is the FX bus stereo (if I route a linked channel to it, does it stay stereo or is it summed to mono before hitting the FX)?
~Bastian
Hello,
I wonder about:
~Bastian
Hello again,
The reason I ask is that I want to run my synthesizers (which have already delay/chorus applied) through the qu internal reverb, and I would like to know if a stereo signal is summed to mono before going to the qu internal FX.
~Bastian
Hi Bastian,
The dedicated FX sends are mono. You could assign a stereo Mix to the FX (or insert on a stereo channel) but most of our FX models (reverbs included) will sum to mono at the FX input stage anyway, and create a stereo output based on the algorithm. This is common practice in most industry standard reverb units - acoustical room reverberation does not follow PANs :), although some true stereo reverbs exist (mostly DAW based plugins I believe).
Hope this helps.
Hi Nicola,
thx, this helps.
~Bastian
