FX Routing to Busses?
Haven’t pulled the trigger on this mixer yet, just playing with the app, trying to make sure that I can get this thing to do everything I need.
Can anyone point me to where I route the FX to the outputs 1 through 6? All I can find are “FX Send Level” and “FX Level to LR”. Where can I control for instance, how much verb is going out to my monitor mixes?
Thanks all!
The manual says to go to processing, and then select the St in BT fx tab, but the fx aren’t showing up. It only displays ST IN, USB, and BT.
Is there a way to get the fx to show up here? An option to check?
Heres the screen for setting fx bus outputs
Here’s what my screen looks like.
Does it not display because I’m not connected to a unit? Seems strange…
@vsthem
The FX channels will not appear and FX will not be able to be sent to outputs if the FX Unit has been inserted into a channel.
But when in Shared mode, you can indeed decide where the FX Unit output is being sent.
So yes, what you want to do will definitely be possible when connected to a unit.
(and I’ve made a note to look into the demo show that is shown by default in CQ-MixPad)
