FX Routing
Hey,
I just updated to 1.92 and suddenly I can’t get my FX to route like it did before??? It works if I use an insert, but I can’t route mix/return - input FX1 Stereo Bus - Op1 Input FX1 left/ OP2 input FX1 right?!?!?!
Anyone else experiencing this?
Loren
Hi Loren,
Which version have you updated from? We changed the way you route FX outputs in V1.8. Use the Unassign / Fully Unassign buttons to revert an effect to factory default (mix/return, from dedicated FX bus to dedicated FX ‘short’ return). To route the FX to another channel, go to that channel’s preamp screen and select the Rack FX output from the source drop-down list. To route the FX to physical outputs, go to the Outputs screen, select a socket and choose the Rack FX outputs from the source drop-down list.
Also worth checking that you have enough FX buses in your Mixer Pref DSP configuration?
Hope this helps.
